Tv - what can I use it for?
dave183
I have an LG flatron tv in my bedroom. I cannot afford to have sky multiroom upstairs anymore and am returning their mini sky q box. What can I do with this tv?
What I watch on my tv? Do I need an aerial?
Rodders53
Model number?
Link to the specs for it?
For UK terrestrial aka Freeview reception you'll need a working UHF TV aerial, assuming the set has a suitable tuner.
tvdavid
could run coax cable from the main aerial if you have one on a 2-way boaster.
or get a games console or use for DVDs or could connect a PC.
dave183
I have a sky aerial that runs to the fish- two wires?
I don’t have an aerial- just the sky aerial that runes to the dish, two lines, that used to connect to old sky box?
JayCee
That's known as a satellite feed, it's not an aerial.
To use your monitor/TV (LG Flatrons are really PC monitors with a TV tuner) you either need to get an aerial fitted or buy a Freesat box which you can connect the satellite downleads to.
CatsWithThumbs
The other option I guess is to connect an Amazon Firestick, I understand these will allow streaming of some live TV channels via WiFi
vickster
Chromecast and cast from a mobile device?
A1944
In Manchester, you might (I repeat - might) get a good signal from the transmitter on Winter Hill. If that is the case then, though it is not normally recommended, you may get sufficient signal with some kind of indoor aerial, preferably one that, at least, looks similar to those you see on roofs.
A satellite dish will not provide any service for Freeview (only Freesat) so that idea can be disregarded,
Try putting your post code into:
to see what indications you get for Winter Hill (or maybe some local relay transmitter).
A Sky (satellite) dish is not normally referred to as an aerial, though technically it may be, so best to avoid that description to avoid confusion.
