kryten22uk
Most tv wall mounts seem to have both a size ratings (ie it says for tvs from 40-60inches) as well as a weight rating (ie says upto 60kg).
Surely the size of the TV is irrelevant? If a mount can support 60kg say then it can support any TV size under that weight.
