TV Wall Mount Advice Needed
shep1968
Hi all.
Shortly i'll be replacing my conservatory and will be able to have a TV wall mounted in there. I'm down to a choice of three but will definitely be a 48 or 49 inch model. I need some advice about the wall mounting. The TV will be fixed higher than ideal so will need to tilt so i have the option of a tilt bracket or a full movement one. The plan is to have everything hidden behind the TV and this will include the electric plug and the sky q mini box.
I want the bracket and tv to look as flush as possible to the wall but there still needs to be space behind it to fit a recessed electrical socket and have a plug in it and a bracket to hold the sky q mini box.
I've only looked at one supplier so far and that is invision and they only do full movement ones. Will a tilt or a full motion one be the neatest and fit closest to the wall or is there no difference? When the bracket is fitted will there be space behind to fit a plug and the q box with the bracket fully retracted, if i go for a tilt only will it go upright with these plugs behind it? Can anybody recommend a decent supplier or manufacturer f the brackets?
Dando8338
Sorry to hijack the thread, but have a similar query. Any TV wall mounts that do a full front to back swivel? I would like to mount my 40 inch TV on an inside wall just to the side of my patio doors. When those doors are open, I would like to swivel it to face outside.
Podcast: REL T/9x Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
