TV Viewing Distance
Discussion in 'General TV Discussions Forum' started by andyp, Apr 22, 2002.
  1. andyp
    andyp
    Jan 2, 2001
    302
    UK
    +7
    Probably quite a simple question, but is there a rule of thumb guide as to the optimum viewing distance back from the screen of a TV? Obviously it will be dependent on screen size, and I guess screen type, i.e. CRT, RP, Plasma etc.??
    Thanks.
    Andy P.
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    As near as possible without seeing scan lines!
  3. Sly Fox
    Sly Fox
    The recommended viewing distance for PAL TV is between 3.5 to 5 times screen diagonal.
    For example; my viewing distance is 2.7m for my small 28" 16:9 PAL Plus (575 scan lines) CRT television. This is the absolute minimum for me to see a homogeneous picture.
    Also see NTSC and Home Cinema , very informative.
    Regards
    Sly Fox
  4. Guest
    does anybody have either a 46, 50, or 56 inch rear projection tv. If so how fa r from the screen do you sit and how do you find the picture?????
