TV/VCR/DVD Sound - help
Discussion in 'Cables & Switches' started by Paulq, Dec 23, 2004.
  1. Paulq
    Paulq
    Nov 25, 2004
    27
    Can someone advise me how to fix a problem I have. I have just bought a
    very nice 24" Toshiba TV which has 2 x Scart sockets. I have used one of
    them with a Scart -> Phono lead into the 'Aux' facility on my hi-fi to
    channel the TV sound through there - this works perfectly for normal TV.
    Trouble is that I also have a VCR and DVD player which I have connected to
    the remaining Scart socket on the TV using one of the multiple Scart
    connectors you can buy. The picture works fine on both but I can't channel
    the sound through my hi-fi when using either of these sources. Not being
    too technical I don't really know why or how (and if) I can remedy the
    problem.
    Can anyone offer me some advice - the whole point was so that my music DVD's
    would sound great throgh my hi-fi!!
    Thanks in advance.
    Paul :lease:
  2. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,382
    113
    Devon, Sussex or somewhere inbetween.
    +566
    I've currently only got 1 scart socket in my TV so I use is one of these:
    http://www.argos.co.uk/webapp/wcs/s...atalogId=2501&productId=108277&clickfrom=name
    DVD, SKY & Video are all connected (but have to be manually switched to change source),and the stereo is connected to the red and white audio out phono connections.
    It might not be the best product on the market, but it'll enable you to use your stereo for everything thats connected. :)
