ChuckMountain
So am in the process of upgrading one or both of my TVs from the current 1080P plasma that they are to 4K OLEDs (probably based around the LG CX variant)
I also have two Yamaha AV amps which I am happy with apart from not being able to pass 4K. If I do upgrade it will be when Yamaha finally do upgrade their Aventage line up for HDMI 2.1 support etc.
Sources include Sky Q v1, Apple TV 4K, Vero 4K+, Panasonic Blu Ray, Sony PS5, Sky Q Mini, Intel NUC.
So I have one TV approx 20m away that is currently connected via HDBaseT with an optical spdif cable returning sound to the amp. The rest of the equipment is in a rack in my garage. Unfortunately, I can route a fibre HDMI cable to it due to the run locations.
Thinking of possibly this but it a bit on the pricey side but appreciate the quality\configuration aspects.
tmfsolutions.co.uk
Is this "visually lossless" compression?
I don't expect to use this TV for gaming but want to ensure I can feed 4K sources to it as well as my 1080P amp which will switch older sources still. Just conscious that we on the HDMI 2.1 becoming more widespread and don't want to buy an HDBaseT box that will become an older model relatively quickly.
Anybody, suggest any alternatives?
The second TV has a 15M run but my devices including the PS5 are local to it. I was therefore thinking that it would be best to hook up 4K devices directly and continue passing sound back via optical. I appreciate that might limit HD Audio for those devices.
@Joe Fernand any other options? Are you still doing RuiPro cables as can't seem them on your store? Are there some 8K or 4k @ 120Hz variants now? As noticed there are some people complaining of issues with 3090 and LG TVs amongst other things.
HDFury Maestro - The Media Factory
Award winning 4K UHD with HDR capable combined HDMI Switch, HDBT Extender and HDMI Audio solution for the ultimate HDMI system flexability.
