Quantcast
Question TV unit help
dbroms
Have been looking for a white high gloss unit for ages but cant find suitable one, sticking point is i intend to buy monitor audio center speaker with 55" inch tv sat on top and house denon avr-x2600h amp, where can my center speaker go ? I cant place on top as it will cover lower part of screen, cant find a tv stand where i can place speaker on shelf on unit as it wont fit. Do i look for a smaller center speaker of keep looking for tv stand. Cant mount tv on wall has to be sat on unit.
Found this one but speaker wont fit in central housing. Centurion Capri White TV Stand with Remote Friendly Glass for up to 65 inch TVs
thedoswells
Hi. Can't you just buy a TV riser?
dbroms
Havent really considered one before, quickly googled but dont look the best do they, maybe need to look into it a little more, cheers though
thedoswells
dbroms
ah ok never seen them before, maybe worth looking into thanks. Just one quick question if anybody has one, if i mount a 55" tv on stand what size is the gap below ? i know it is adjustable but will it give me at least 165mm 6 inches below the bottom of the tv to allow me to put center speaker on ?
