tv tuner card
Discussion in 'Desktop & Laptop Computers Forum' started by H4r7y, Oct 3, 2003.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    just wondering if its worth getting a tv tuner card for my htpc. would it be able to decode digital tv channels? i am able to get some channels on my tv, but have noticed that theres channels coming through that i can hear but cant tune in to view. would i get a better reception from using this type of card?
  2. gab2001uk
    gab2001uk
    Dec 3, 2002
    236
    +5
    On normal (analogue) TV, it is common to get other channels with poor or no picture, such as other ITV regions. These are from weker signals from other transmitters in your area. If you use a digital (Freeview) box and your signal is poor, you will get pixellation, break-up and other effects on the digital channels. It is worth getting a better aerial first. Once you get a good quality signal, then you should get an excellent picture from a card. (Nebula DigiTV is the best)
