Tv tuner card needed for laptop
Discussion in 'Desktop & Laptop Computers Forum' started by deadred, Jul 28, 2005.
  1. deadred
    deadred
    Nov 18, 2004
    2,785
    Cumbria
    +130
    I own a Benq Joybook 8100 and would like a TV tuner card for it, i was wondering any recomendations. And do i need to plug a coax into it to recieve a picture or does the card itself act as the antenna
  2. Logan09
    Logan09
    May 27, 2005
    65
    Whichever TV tuner you buy you will need a signal for it (either coax from you aerial, or other connection from a set top box). As for which tv tuner, obviously you will need a USB tv tuner, but you need to specify what type of tuner you want? A standard analogue tv tuner, freeview, satellite?
