Answered TV to Soundbar connection ,
Discussion in 'Soundbars, Soundplates & Soundbases' started by natsnats, Jul 25, 2018.
  1. natsnats
    natsnats
    Jul 25, 2018
    3
    E14 2DQ
    Hi All , i need to connect my Old LCD TV ( one with Analog cable i/p and head phone hack and NO Optical i/p)) with my new sound bar which has a HDMI arc i/p and Optical i/p. However, I am unable to do so as I have a HDMI (not the HDMI arc) cable and connecting the TV with soundbar using this cable does not work , What can i do to connect them ?
    TV model : 32BV701B ans soundbar model : sony HT-SF200 2.1 All-in-One Sound Bar
  2. Best Answer:
    Post #9 by Joe Fernand, Aug 13, 2018 (1 points)
  3. JayCee
    JayCee
    Jan 20, 2004
    24,011
    Lanarkshire
    +2,620
    Welcome.
    It's always a good idea to give the brand and model nos with a query like this.
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    'TV model : 32BV701B ans soundbar model : sony HT-SF200 2.1 All-in-One Sound Bar' - you require a Digital Optical Cable to connect the TV Optical Out to the Soundbar Optical Input.
    Joe
  5. natsnats
    natsnats
    Jul 25, 2018
    3
    E14 2DQ
    Hi Joe , the TV is an old one and i do not have a Digital ip or op in the TV. I have 2 HDMI posts and normal RCA cable ports / headphones jack
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    Just had a look at the TV User Manual:
    TV Digital Out is on a Coax socket.
    Soundbar Digital In is an Optical socket.
    You will require:
    1 x RCA>RCA Cable
    1 x Coax to Optical converter
    1 x Optical cable
    Joe
  7. natsnats
    natsnats
    Jul 25, 2018
    3
    E14 2DQ
    Thanks for your suggestion Joe .I have not tried your solution but i have managed to get a bluetooth transmitter and connected that to the headphone jack of TV . I have then connected the soundbar with this bluetooth transmitter , I can now hear the TV sound from the soundbar . i will try your solution as well . Meanwhile , the Sound bar has a HDMI ARC port as well . and my TV has a HDMI port , I was wondering if i can connect the devices using a normal HDMI cable. I tried but it did not work.
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    HDMI ARC - only works if both devices have ARC enabled HDMI sockets, you also need to enable HDMI Control plus ARC on both devices.
    HDMI cable - any HDMI cable ought to work with ARC.
    Joe
  9. johnr2110
    johnr2110
    Aug 26, 2006
    2,760
    2
    3
    68
    Eastbourne
    +94
    Apologies for hijacking thread. How do you enable ARC on a TV nothing found in Menu?
  10. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    Best Answer
    One of the HDMI ports on your TV has to be ARC capable before you can enable the Feature - which TV do you have?
    Joe
  11. johnr2110
    johnr2110
    Aug 26, 2006
    2,760
    2
    3
    68
    Eastbourne
    +94
    A Panasonic TX55EZ952B Oled
  12. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    HDMI Input 2 on the TV is ARC capable.
    Connect the TV HDMI Input 2 to the ARC port on your AV Amp - then you will need to enable ARC on both devices - which usually also requires you to enable HDMI CEC 'Control' (VieraLink on a Panasonic) on both devices. Then you ought to have the option of enabling ARC - it is not the most simple Feature to enable at times.
    Joe
  13. johnr2110
    johnr2110
    Aug 26, 2006
    2,760
    2
    3
    68
    Eastbourne
    +94
    Just on or off currently on.
    Finally hoping to get a Sonos Beam which for best results should be connected to the ARC socket which is one of the hdmi 4k ports, which is being used, problem?
  14. zeppelino
    zeppelino
    Jan 24, 2018
    3,938
    134
    UK
    +1,211
    The Beam comes with an adapter that allows you to use an optical cable.
  15. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    As above not for the audio signal - from the SONOS BEAM FAQ:
    What is HDMI-ARC?
    Sonos Beam connects to your TV’s HDMI-ARC port. Most TVs have two to four HDMI ports, one of which is labelled ARC, which stands for Audio Return Channel. The HDMI-ARC port syncs audio and picture, plus automatically pairs your TV remote to Sonos Beam. If you’re unsure if your TV has an HDMI-ARC port, consult your TV specs with the manufacturer.
    If your TV is older than 5 years, or otherwise doesn't have an HDMI ARC port, you can use the included optical audio adapter to connect Sonos Beam to the optical port on your TV. Please note that Amazon Alexa TV voice commands will not work when connected via optical adapter.
    I wouldn't worry about Optical vs. ARC.
    Joe
    PS If required you could add a suitable HDMI Switch to one Input on the TV to allow you to connect the BEAM to the TV ARC port plus have all of your UHD Sources connected to the TV.
  16. johnr2110
    johnr2110
    Aug 26, 2006
    2,760
    2
    3
    68
    Eastbourne
    +94
    Thank you for the help.
