TV to Projector
Discussion in 'Freeview & YouView' started by merlin41, Aug 27, 2006.
  1. merlin41
    merlin41
    Aug 13, 2006
    78
    11
    Worcester UK
    Hi everyone
    I am just setting up a system with Hitachi PJ200 Projector & Denon AVR1906 receiver etc. How can I best introduce TV into the system without using a computer and TV card etc. Is a Freeview box the only way and how is this connected to get the best quality picture?
    Thanks :thumbsup:
  2. sbowler
    sbowler
    Mar 24, 2005
    3,799
    Leeds
    +481
    You can add as you say a Freeview box, which will give the best picture quality when set to RGB output via its scart socket. Another option is a VCR which will give you an analogue signal to the PJ, this will also connect via a scart socket.
