tv to pc to dvd help
den9112
not sure if i am in correct place but will give it a try . i am very familiar with dv capture edit and burning , i have adobe prem pro and encore to do this . what i want to try now is music footage direct from my tv to my pc and do all the editing rendering etc and put it on dvd i know i will need a tv card to capture , can anyone start me off ie software and what you save as and size of files i have had some great response in the past hope you can help thanks in advance dennis
B
Brian110507
I use Ulead VideoStudio7 to do just that saving them as .mpg files which are quite a bit smaller than DV-AVI, just a matter of changing settings within the programme to capture analogue instead of digital. don't know about your programmes I have never used them.
Podcast: CES '22 TV Announcement Round-up, Plus, Most Anticipated Movies of 2022 and More...
