Tv through digisender to PC
Discussion in 'Desktop & Laptop Computers Forum' started by simpav, Mar 29, 2005.
  1. simpav
    simpav
    Feb 19, 2005
    27
    3
    Hi, I am looking at the possibility of sending the signal from a TV to Digisender connected to a PC so i can watch TV on the PC without having to connect a portable aerial to the PC.
    The card on the PC is TV-7135/FM tuner card and the connections are
    TV antenna input
    FM radio antenna input
    S-VHS/Audio L + R/Composite video input via spider cable
    Is this possible? If so how would I connect the digisender to the PC as I they have SCART connections.
  2. Spacecat
    Spacecat
    Apr 1, 2001
    3,349
    London
    +982
    I have a PC to Tv digisender which works great.
    The reciever on the normal digisender has a composite input, which you could hook up to your PC if it has VIVO via composite
