TV that displays Progressive Pal
Discussion in 'Projectors, Screens & Video Processors' started by mlinhares, Jun 10, 2002.
  1. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    I'm going to buy a new TV, but as I have a Arcam DV88 DVD player wich can be upgraded with a board to progressive pal I would like the TV to accpet and display progressive pal. Is there such TV in the market or is it going to be in the near future? (I saw the Loewe with VGA board, but we couldn't have geometry corrections).
    Thanks.
    Miguel Linhares
  2. magking
    magking
    Jan 6, 2001
    380
    Norway
    You would need a HDTV or plasma TV i believe. I dont think you can get any HDTV's in Europe, but if you got the cash for it, a plasma will handle it.
  3. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,454
    Norwich
    +947
    what about the new toshiba, this takes a progressive signal not sure about pal prog though.
    read the posts about it in the tv section of the forum, someone may know by now.
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,454
    Norwich
    +947
    Here is the link to the thread.
    take your dvd player into a store and try it on the set.
  5. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    I have downloaded the Toshiba 32-36ZD26P manual and I believe it only does NTSC prog. scan and not PAL prog. scan.
  6. MartinCo
    MartinCo
    Apr 4, 2001
    853
    Liverpool
    I'm not sure..the manual only mentions the progressive mode once and isnt very clear about it.
    it just state something like "most usable on NTSC"... which would imply it does do PAL progressive depending on your interpretation.
    be surprised if it wasn't able to do pal if the official format is imminent as has been suggested.
  7. CoolioCat
    CoolioCat
    May 29, 2002
    45
    I recall looking at the spec sheets for these two new Toshibas (stunning units indeed) on one website - and it actually mentioned 'PAL PROGRESSIVE SCAN'. I noted it because of the rarity you see PAL and PROGRESSIVE ever mentioned on a shop website :) I believe it was empire-direct, but it might have been unbeatable.co.uk or perhaps HED.
    Perhaps it has a little switch on the back which moves between PAL and NTSC, like the older Pioneer DVD models :) Or even on the remote! We can hope. :D
  8. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    mlinhares
    I waiting for my Tosh 32ZD26P. Where did you get the manual from? Any chance of a link? :)
    Many thanks
    Paul
  9. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
  10. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Thank you very much mlinhares :D
    Its helpful people like you who make this forum so resource it is
    Many thanks
    Paul
  11. mlinhares
    mlinhares
    Jul 1, 2001
    354
    Portugal
    Hi Oblivion could you confirm if it can do Pal progressive.
    Thanks.
  12. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Not yet, still awaiting the set. Some one else has confirmed it will display NTSC Prog Scan though. Have a look here I think McPastry confirmed it buy taking his US game cube in to power house.
    Paul
  13. McPastry
    McPastry
    Suppose another way to test it would be to get my US Xbox chipped and run a PAL game on it (this will output PAL progressive according to museumsteve). Or one of you rich peeps could take your Arcam into Powerhouse and give it a try? :D
  14. laurie
    laurie
    Nov 23, 2001
    145
    16
    Sydney Australia
    yes I believe thats right but at 480p! not 525p
    cheers Laurie
  15. McPastry
    McPastry
  16. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,454
    Norwich
    +947
    480p and 525p are both ntsc just different ways of describing it.
    576p and 625p are both PAL just different ways of describing it too.
    sorry :rolleyes:
  17. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    The Toshiba 32zd26p has been confirmed as NTSC
    Paul
  18. alpha10
    alpha10
    Jan 22, 2002
    3,200
    Essex
    +193
    I'm a bit confused now, you say yes to both NTSC and PAL, but I thought I had just read on the mega post under tv etc that the PAL part hadn't been verified??
    Mark.
  19. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Sorry seems that the DVD player used converted Pal to NTSC and then Progressive Scan so only NTSC is confirmed :blush:
    Paul
  20. andrew constant
    andrew constant
    Apr 15, 2002
    216
    london
    +11
