Tv stand to fit antec fusion
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by revilo22, Feb 10, 2009.
  1. revilo22
    revilo22
    Feb 10, 2009
    4
    Just got a LG 32PG6000, already have a HTPC based on an antec fusion case. Im stuggling to find a bottom shelf deep enough to fit the HTPC (depth 42cm) without the rear legs (or cable management) getting in the way. Budget is limited (£40-70). Has anybody got a solution that they use??
    rev
