Tv Speakers off or on when using Surround?
Discussion in 'Home Cinema Buying & Building' started by Bales1983, Jun 17, 2004.
  1. Bales1983
    Bales1983
    Just wondering if the TV stereo speakers should be used when using a 5.1 surround kit or should they be silenced?? Will using them add to the experience or just ruin the surround effect??
    Lee
  2. watchmaker
    watchmaker
    Aug 22, 2003
    168
    +15
    In general they should be off.
    Some TVs may have the option of playing the centre channel through the speakers but this is fairly rare and even then you mightn't want to do this.
  3. Bales1983
    Bales1983
    Many thanks for the reply mate, advice noted.
    Regards
    Lee
