TV sound on sony DAV-SR1
Discussion in 'Home Cinema Buying & Building' started by rockysocks, Apr 11, 2005.
  1. rockysocks
    rockysocks
    Hi, I just bought a sony DAV-SR1 (all in One home cinema kit) I have connected it to my Sony TV through the RGB scart Connection. When in DVD mode slightly muted TV channel audio is coming out of my TV speakers at the same time as the DVD Audio from my surround sound speakers. So during quiet spells of the movie I can here the television. Any advice on reason for this and possible fixes. - Thanks
  2. steel_kelly
    steel_kelly
    Apr 7, 2005
    150
    middleton, manchester
    +21
    if you have sky or cable try pressing mute.
  3. rockysocks
    rockysocks
    I do have freeview and when I press mute on the television or the freeview box I get a Mute symbol on the screen while watching the dvd which is not really acceptable.
  4. Camperman
    Camperman
    Apr 8, 2005
    40
    I have to mute the TV only when the unit is set to output the TV sound (you can hear an echo if not) the TV does not display a mute sign so this is not a problem. I have never experienced a problem when watching a DVD. Perhaps you could set the TV to a channel with no sound output, perhaps a text channel. It is not ideal but may help.
