TV signal Amplifier & Distribution unit
Discussion in 'Satellite TV, Sky TV & FreeSat' started by TheSeer, Oct 26, 2003.
  1. TheSeer
    TheSeer
    Dec 23, 2001
    142
    Hampshire
    +3
    Hello all,
    I am looking for a good quality TV signal amplifier & distribution unit. I want to feed the signal from the aerial into this and then distribute the ampified signal to appx 10 sockets.
    I will mainly use the amplified signal to drive Freeview STB's.
    I would be very grateful if anyone out there can recommend a high quality, low noise amplifier/distributor that will not do significant damage to the Freeview signal. If necessary, I can provide a good quality, low-noise mains feed.
    TS
  2. brendank
    brendank
    Dec 13, 2003
    639
    drogheda, co louth,ireland
    +6
    interseted in reply if any to this
  3. morphy
    morphy
    what sort of cable run distances are u looking at from min 2 max, need a bit more info mate
  4. brendank
    brendank
    Dec 13, 2003
    639
    +6
    opps sorry
    not quite sure how it is set up
    aerial to main tv room on second floor 52 feet and 70 feet (2 sockets)
    aerial to bedroom 1 on 3rd floor 22 feet
    aerial to bedroom 2 on 3rd floor 32 feet
    aerial to bedroom 3 on 3rd floor 44 feet
    aerial to kitchen on 2nd floor 86 feet
    aerial to playroom on first floor 112 feet
    thanks
  5. Flipper
    Flipper
    Nov 27, 2003
    208
    28
    +26
    I installed a LabGear 4-way amplifier/distributor box in my loft last year. It works a treat. I used almost all of a 100m coax reel running cables to aerial outlet sockets. Works fine with my freeview box.
    Have a look at their web-site, they have loads of these sort of products. http://www.labgear.co.uk
  6. JefUK
    JefUK
    Mar 31, 2002
    444
    28
    +53
    I use an Antiference 6 way distribution amplifier in the loft in a DTT fringe area with good results. Available from Maplins.
    See http://www.antiference.co.uk/
  7. morphy
    morphy
    brendak: televes or antiference products are both adequate for your needs mate as long as youve got a reasonable signal coming in the first place, available from most sat aerial distributors
