TV Show / Film Synopsis too long
Sebastalona
I've transferred the above to my iTunes library using both iVI and Handbrake/Subler.
I noticed that both sometimes use the long description, so that you can't read the whole thing on the summary screen on the ATV.
Is there a setting in iVI /Subler you can choose so it will only use the short description for display on ATV?
I thought you might be able to somehow expand the long description but it doesn't look like you can.
Desmo
This does my head in too sometimes. I tag using other progs and make sure I only use the short description.
Sebastalona
What do you use mate?
Desmo
Either use mkvtomp4 when I'm converting or MetaX for just metadata. These are both windows only though. Doesn't subler do metadata on the Mac? Might be worth taking a look.
Sebastalona
Yes, I use Handbrake and Subler but sometimes the short and long descriptions are the same (and still too long).
next010
You could cut them down in iTunes use get info on item then under video tab see description section.
Sebastalona
Yeah, I suppose that's an option. I was more hoping for a 'fire and forget' solution! Could be quite time consuming going back through everything.
Sebastalona
IMDB has this kind of little overview for every film which would be perfect:
bpsmith
I use IVI and the descriptions are all fine tbh. I usually watch TV stuff so suppose I can't comment too much on Movies but will check for you.
Sebastalona
Well, after a session of random button mashing I've found that by pressing up on the Apple remote whilst the movie is playing brings up the whole film description. Not ideal, but at least can read all of the synopsis.
However, if anyone comes up with solution to enter the short description by default I'd be glad to hear it.:thumbsup:
bpsmith
Up once shows you how much watched and how much left. Up twice shows the synopsis. Up three times goes back to just whats playing.
Sebastalona
Yeah, found the chapter select too:blush:
:laugh:
