TV power cable in drywall
Discussion in 'Home Cinema Buying & Building' started by olville, Jan 10, 2012.
  1. olville
    olville
    Jan 1, 2011
    3
    +6
    Sorry in advance as this will have been spoken/wrote about before.
    Can you install a TV power cable behind a plasterboard (drywall stud partition) without breaking any laws etc.
    I have read about a "power outlet" but most of the clips and reviews are anything other than UK stuff.
    Are there any kits etc, that I could possible buy?
    Any advice would be very helpful :thumbsup:
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    23,923
    Poole
    +9,300
    I would be careful, the softer plastic in mains leads doesn't have the same service life as proper mains wiring.
    This is due to the pasticisers used so it would be worth seeing if you could fit a double socket.
  3. Iccz
    Iccz
    Apr 29, 2008
    24,052
    Keystone City
    +6,750
    Moved to the general advice/info board as the gallery is for pictures :)
