Tv/pc
Discussion in 'Desktop & Laptop Computers Forum' started by baldbird, Dec 3, 2003.
  1. baldbird
    baldbird
    right, here's my plan.
    A pc in my dining room with 5:1 speakers so i have music in my dining room. then connect the pc to my tv etc so i can watch anything on my pc on my tv if i want. Spec wise my systems up to it - p43ghz, 120HDD, good sound and graphics card - but nothing on for tv-out.
    Any suggestions as to the best way to do it ?
    cheers
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Best TV-Out I've found is Radeon-based, a 7500 was fine, a 9600 non-Pro is great, allows higher-res though in practice on my 28" Tosh 1024x768 was only just about usable as a desktop resolution, for video playback 800x600 is fine .. is this what you're asking?
  3. mephistopheles
    mephistopheles
    If you have/get a Radeon you might want to try it this way :-
    http://www.idiots.org.uk/vga_rgb_scart/index.html
    I haven't tried it myself but it looks to be sound in theory and relatively easy to do!
    Alternatively, a transcoder might produce a better quality signal for desktop.
  4. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Would RGB make any useful difference on a TV? PJ/plasma yes, but would a normal TV benefit from this?
  5. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,718
    71
    Land of the Living, Essex
    +34
    There would be an improvement as you would no longer be using the scaled tv-out chip, it would be direct from VGA at the correct video resolution
  6. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    The Garden of England
    +32
    Is this sort of thing any good?
  7. baldbird
    baldbird
    Wireless or not doesn't bother me too much. just the best way of doing it. I basically want to start using my PC as my media system for the house but(as I think a lot of us are) I don't want my pc in the living room - i like to have one room - music one room - tv so pc in music but connected to tv. so i need to know the best output to the tv (i think) !
  8. mephistopheles
    mephistopheles
    The signal to TV will be limited by the TV's resolution and refresh rate, won't it? Not such a problem with 100Hz TV, but standard PAL TV signals are very low res/refresh. Nevertheless, you will get much better image from RGB than S-Video TV-out, which is only moderate-poor quality.
    A Radeon would be the card to get, really, so you could try it with S-Video TV-out. If it's OK for you stick with that. Otherwise try either a transcoder (don't recommend any of the wireless video senders) or making up your own VGA->SCART cable. Alternatively, retire the TV and use the PC + capture card + DScaler on a decent screen. You won't regret it.
  9. Kramer
    Kramer
    The X-card offers RGB out (optional IIRC) & would probably be the better option. Haven't used it though.....
  10. mephistopheles
    mephistopheles
    Limited to DVD and MPEG4 etc. with SCART add-on though. Otherwise uses VGA pass-thru.
  11. shoehorn
    shoehorn
    Jul 2, 2003
    1,602
    +32
    How about trying this ?
    I just read about it in another thread (Wireless audio from PC to HiFi) - JohnG found it...
    might have to get one myself.....
