TV Output possible?
Discussion in 'Desktop & Laptop Computers Forum' started by scrapbook, Mar 4, 2003.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,188
    +546
    Anypne know whether it is possible or of a gizmo that allows output to a television other than by SVHS as I dont have this connection on my TV?
  2. mephistopheles
    mephistopheles
    Presumably :-
    1/ There is a SCART socket on the TV (and it probably accepts RGB and composite video signals if there is no s-video).
    2/ You are outputting from PC via a video card with TV out which provides s-video and composite video signals.
    Therefore :-
    You can get a SCART adapter with s-video, composite video & stereo audio connections and hook up with RCA -> RCA composite video (+ stereo audio) cables. Unfortunately, composite video is not a high quality signal and it is likely to be unsatisfactory.
    Alternatively, you could invest in a scan converter and ouput to TV from the video card's VGA socket to get an RGB signal to the TV.
  3. Paul O
    Paul O
    Nov 2, 2000
    481
    UK
    +21
    I use a dongle similar to this - picture attached...
    Front end is scart, the back end is either S-VHS, Composite and the audio.
    Scart goes straight into the TV. Jobs a good 'un.
    Got it from a local electrical shop, but I'm sure dixons or somewhere similar will sell em.
    Hope this helps.
    Paul.
