tv out query
Discussion in 'Desktop & Laptop Computers Forum' started by H4r7y, Jan 4, 2004.
  1. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    anyway of getting tv out into a tv that doesnt have a scart socket?
    cheers
  2. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +88
    Hi H4r7y,
    What connections do you have on your TV and PC video card ??
    Maybe you could try s-video or composite video ??
    Cosmci023
  3. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    the tv has only got rf input and my gfx card has got svhc and comp out.
  4. cosmic023
    cosmic023
    Feb 15, 2003
    1,369
    48
    Somerset
    +88
    Hi H4r7y,
    I'm afraid a modulator is the only way to go..... :(
    You could get something like this from Keene........
    Keene Modulator
    If it doesn't show, put in product code (KRF) or do a search 'modulators'........they do others but that's the cheapest @ £19.99.
    Maybe it's time to get a better TV ?? Most cheapy TV's have RGB scart on them for less than £100
    I hope this helps........
    Cosmic023
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    thanks for that cosmic, its a portable which is sat in a spare room, its not my main tv :) just thought id be able to wire it up to watch some stuff from my pc
    cheers
  6. Warpaint
    Warpaint
    Jul 26, 2003
    591
    28
    Edinburgh
    +61
    Have you got a video recorder connected to this TV?
    If you do then you could connect your TV out into the VCR's scart socket and view the PC through the VCR using composite out and audio out if you want sound.
  7. H4r7y
    H4r7y
    Jun 17, 2003
    1,701
    39
    Nottingham
    dont have a vhs near it
    thanks for trying though
