TV Out Graphics card
Discussion in 'Desktop & Laptop Computers Forum' started by DazJWood, Mar 12, 2003.
  1. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    Ideally I would like a graphics card that allows tv out to work as soon as the pc is turned on.
    A friend of mine has a computer that outputs to the tv as soon as it is turned on. He thinks it is some kind of ATI card.
    Most graphics cards with tv out only seem to output when windows has booted up. For a home cinema pc this is ok as long as the system does not hang or crash at some point before. If it does it means having to then connect a monitor to it to resolve the problem.
    Can anyone give me suggestions for Graphics cards that allow output as soon as the pc is powered up.
    Thanks,
    Daz
  2. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    Is there really nobody who knows the answer to this one?
  3. Lem
    Lem
    I have used both the Radeon and the GF4MX built into the nForce chipset and they both do TV-Out from boot-up. May well be that your BIOS settings are different to your windows settings for TV Output eg NTSC/PAL UK used PAL-I
  4. dukebox_1st
    dukebox_1st
    Feb 2, 2003
    26
    Edinburgh
    my geforce 4 4600 will boot with a tv as monitor and show the entire bootup, however i suspect it has to b set to b primary monitor inorder to show the boot. my current setup has dual tfts and only one sdisplays an image during startup while the other waits until it breaks into windows before display anything,
    hope that helps
    tom
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    yes it depend on weather its the primary monitor or not, well thats for the gf4 mx's, anyway. my Ati r9500 will display on both monitors up until you actually get into windows and the drivers take control. (or monitor and t.v depending on if the second monitor is connected or not)
