TV Out Cable for IBM T22 Laptop
S_Bob
you will need to adjust the Screen Resolution.
If you go to control panel > Display > Settings. The setting will depend on what TV you have. try changing the settings until you get it right. I think 1024 x 768 is for the normal old non widescreen TVs. You can then set the media player to full screen.
Not sure about the black and white, maybe change setting to PAL (also somewhere in Display).
