tv or screen ?
Discussion in 'Plasma TVs Forum' started by gesthetrain, Jun 9, 2005.
  1. gesthetrain
    gesthetrain
    is there a difference,can i just hook up for example Panasonic TH-42PWD7BK Plasma Screen the same as i have my normal ten year old tv with aerial + sky + video + dvd player? or am i being a bit silly?
  2. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    its not quite that simple. Firstly, wouldn't bother with terrestial....secondly you need input boards to connect the other equipment too and there are several options such as scart board, component, vga (the only one that comes as standard)........try the beginners thread...it's long but the info is all in there. Also video is never going to look good on a plasma and would strongly recommend dvd recorder.
