Quantcast
tv monitor combo or tv???
rubbertatti
I'm after a full hd tv that can also be used as a monitor.
I dont know whether to go for a tv/monitor combo or a mid range tv.
I have a free view box with hdmi output so could go with a monitor if it will work:confused:
spyder viewer
Size?
rubbertatti
something around 30"
I have found an Iiyama Prolite X2377HDS 23"
Features:-
- Diagonal 23" Panel IPS
- Display area h x w 286.4 x 509.2 mm; 11.3" x 20"
- Response time 5 ms
- Contrast 1000 : 1 typical
- Contrast 5 000 000 : 1 ACR
- Brightness 250 cd/m² typical
- Viewing zone horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour 16.7 million Pixel pitch h x v 0.265 x 0.265 mm
- Native resolution Full HD 1080p, 1920 x 1080 ( 2.1 megapixel) Horizontal sync 30 - 80 KHz Vertical sync 55 - 75 Hz Synchronization Separate sync
- Aspect ratio 16 : 9
- VGA, DVI & HDMI inputs
- 3yr Warranty
which part of the specs in bold corisponds to the the output frequency of the free view box? vertical sync?
