tv listing problems
Discussion in 'Satellite TV, Sky TV & FreeSat' started by duncan, Nov 25, 2003.
  1. duncan
    duncan
    can anyone help?
    i have got a PACE digi box and i have been having a lot of problems recently when i try and access the menu's. it takes forever for them to load up, thats if they do at all. sometimes it just freezes altogether.
    is this a problem that can be fixed? if not what is the best replacement digibox to get?
    thanks in advance
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    Welcome to the forums :hiya:
    This sometimes happens with "dodgyboxes" it may be that a simple reset will cure it... unplug at mains (not at box), leave for 10 minutes then plug back in wait for 2 minutes and switch on with remote.
    Witrh any luck things should be back on track... failing that check out the informative www.satcure.com or post back here ;)
  3. duncan
    duncan
    i remembered a SKY technician telling me to do that, i have tried it a couple of times and it seems to work for a coupl eof weeks but then slowly goes wrong again.
    thanks for the link to that site, i will go and have a look. It is looking like bad news though isnt it. :rolleyes:
    any idea on what the best box would be to buy second hand?
    thanks so far
