Tv links
Discussion in 'Satellite TV, Sky TV & FreeSat' started by DarT, Oct 29, 2003.
  1. DarT
    DarT
    Oct 25, 2003
    58
    Derbyshire
    I am currently running normal Sky digital distibuted via 2nd RF output through a 4-way in the loft to other tv's in the house. I also use a number of TV link with sky remotes in some of the rooms to control the sky.
    Now that i am considering uprating to Sky+, does anyone know whether the TV links and remotes will still work with a Sky+ box.
    I appreciate that the remotes will possibly not work fully, but the ability to change the channel you are watching is all that is required.
    Anyone any experience or know the answer.
    Regards
  2. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    There's no reason that the RF output won't work in exactly the same way and afaik the remote codes are exactly the same as well.
  3. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    The tv link worked fine after my change to Sky+
    Changed to a digisender now though, as 'the boss' didn't like the cabling :rolleyes:
  4. ndenbow
    ndenbow
    Oct 20, 2003
    482
    Herts
    +11
    What digisender did you use?
  5. Cadire
    Cadire
    Oct 18, 2003
    146
    Sussex
    +10
    I used the X2 model (so I can hook up my DVD to watch upstairs too). Was £69 from Argos if I remember right.
    Works a treat too.
