TV Links Playing up on Sky plus
Discussion in 'Sky Digital TV Forum' started by marchdj, Jun 8, 2005.
  1. marchdj
    marchdj
    I have searched other threads but can’t really find any help:
    I have purchased a new Philex SLX6B amplifier with bypass which is in my loft, then feeding 5 rooms. The aerial cable in the loft is connected to my new V2 Sky Plus RF2 output.
    However, whilst the red lights are always on on the Global TV Links used in all rooms (although I have only ever have one link connected at a time for testing), periodically the link stops sending any signals to the digibox but the red light stays on all the time without a flicker.
    Key Points:
    • The RF2 is connected properly to the digibox with the power switched on
    • I have tried on a normal non sky + box which still has the problem
    • I have tried two new Sky remotes with new batteries
    • I have tried two different Global TV Links
    • The picture is very good (especially when considering it is coax cable)
    • If I disconnect the link from the cable to the SLX and reconnect it after a minute or so it usually works again.
    Maybe the amp doesn’t like Global TV Links or the SLX amp has these problems (I had to return the first new SLX as it was faulty)?
    Any ideas, all help appreciated!
  2. John Griffiths
    John Griffiths
    I am also a new member and I have the same unit and the same problem. The magic eye lights up going into the amplifier but does not light up on the output side. Did you get yours working in the end. I am on the 2nd unit, with no success.
  3. aa421
    aa421
    Jul 12, 2006
    54
    Hi guys,
    I was just about to buy one of these for a similar set-up. Did you get it resolved?
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    22,493
    Redditch
    +3,729
    Try fitting a dc bypass to the amp input and output. B&Q sell them
    Example here
    http://cgi.ebay.co.uk/MAGIC-EYE-BY-...3|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
  5. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +309
    Maybe you didn't use double-screened cable and solder the plugs?
