tv-link
Discussion in 'Satellite TV, Sky TV & FreeSat' started by garye, Oct 15, 2001.
  1. garye
    garye
    please could someone (maybe a sky engineer) advise on why my tv-link has suddenly stopped outputting the 9 volts it is meant to? also would this affect the standard of picture on the 2nd tv? :confused:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Not an engineer but,
    Has a software update reset the TV link output, worth checking if you haven't already.
    Services-4-0-1-Select-RF Outlets
    If it's activated then has your second remote got working batteries?
    Had to ask :)
    The picture on the second TV shouldn't be affected as the power is only used to carry
    the remote codes upto the main box.
    Try connecting the second TV to the standard RF output instead of the powered one just for comparison.
  3. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    Sorry to say, but the signal to your second TV is affected if the 9v isn't going through.
    I have just upgraded my Digibox and it's RF voltage wasn't on.
    Didn't discover this until I put my second TV on and discovered that the picture was all snow. Also there was no Sky signal coming through.
    Once I put the RF voltage on my second TV was back to it's usual self.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Just turned the power off to my TVlink and the picture on the second TV is unaffected.
