TV Link Question
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Zarch, Nov 6, 2003.
  1. Zarch
    Zarch
    Jan 23, 2003
    3,531
    Sheffield
    +827
    Currently I have cabling coming out of TV2 out on the the SKY box up to a TV set in bedroom 1 using a tv link to change channels from up there.
    I then split the signal at the tv and currently pipe it into bedroom 3, where i can watch the pictures in there.
    Could I get another tv-link and remote and change channels in bedroom 3?
    If not, what would I need?
    Mick
  2. Zarch
    Zarch
    Jan 23, 2003
    3,531
    Sheffield
    +827
    dont worry, i dont know where bedroom 2 went to either!! LOL!
  3. Fernsehman
    Fernsehman
    No. The TV Link signal can't pass through a splitter. Also the first TV Link will block the 9 volts AND the signal from the second TV Link. You can't "daisy chain" them. What you must use is a two-output amplified splitter. Feed the Digibox to it then feed each output to a TV via a TV Link.
    The amplified splitter (or distribution amplifier) must be a "SkyLink compatible" type. "SkyLink" is the generic term for the various digital remote extenders, TV Link, DigiLink, SLXlink etc.
