TV Link for Sky Digital
Discussion in 'Sky Digital TV Forum' started by common, Feb 20, 2002.
  1. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Is there anyway you can use a TV Link to distribute sky round the tv arial sockets in my house ?
    I'm not using the TV arial socket in my front room so the RF out can go to that via the TV Link - but do I then need a 'loop' to capture all the other sockets ?
    Or shall I just get a video sender from Argos etc !
  2. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    Sorted this at the weekend if anyone is interested.
    Went to the loft and looped the arial sockets together with a female to female coax connector and I now have sky in the dining room and bedroom for £16, I have a couple of old sky remotes so they are used for changing channels.
    What a result
