TV Link directly into TV a no,no??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by dickst3, Oct 20, 2005.
  1. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    I plugged my TV link directly into a set in our bedroom and now I cannot tune the TV at all. I ran it through the tuning scan and it picked up nada. :confused:
    I remember reading here somewhere (I have tried a search) that you should not plug TV LInks directly into the back of the TV and instead should use a small length of coax - is this correct? Does it cause damage? :eek:
  2. JayCee
    JayCee
    Jan 20, 2004
    24,162
    Lanarkshire
    +2,652
    The main reason it is suggested not to plug it in directly to the aerial socket is because of its weight/length making it more likely to weaken/break the aerial socket.
  3. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    So it doesn't do any damage internally?
    I wonder why it won't tune then :confused:
    Thanks for the reply. :)
  4. JayCee
    JayCee
    Jan 20, 2004
    24,162
    Lanarkshire
    +2,652
    None at all.
    What Make/Model of TV?
  5. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    thats good news :)
    i will check.....
    thanks again :smashin:
  6. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    its a philips with the clock in the front and two front legs and is all lit up when on.
    turns out we were trying to tune the radio in it - i didnt know it even had one :oops:
    all works fine now :smashin:
