tv link and amplifier problems??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tukky, Apr 20, 2002.
  1. tukky
    tukky
    I have a panasonic sky box with a second output running into a global communications amplifier and then out to two other televisions. One of the televisions has a tv link on it.
    Every so often the picture on both televisions feed by the amplifier are scrambled but i still get perfect sound. The main tv is ok. Nothing i do will correct the problem. I turn the tv's off and leave them, then when i tun back on they work!!!
    When the picture scrambles the light on the tv link also goes off.
    I contacted global who said to check all the connections were ok and then to try the tv link directly in the rear of the sky box to check to see if it is the wire - but if its the wiring surely it would not work at all???
    Has anyone had similar problems with tv links/amplifiers - I am stumped at the moment on what to do!!
    Neil
