tv in corner
Discussion in 'Home Cinema Speakers' started by jelly, Nov 14, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    hi felas at the mo i have my tv flush against a wall with my sofa against the opposite wall if i was to put the tv in the corner and my fs1 front speakers about 4 feet out the corner would they sound ok
  2. fred123go
    fred123go
    Sep 16, 2003
    1,040
    39
    Cobham, Surrey
    trial and error would probably be your best answer, try it and see
    Fred
  3. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    in your HC set-up do you have your tv flush agaibst the wall or in the corner???
  4. krusty
    krusty
    i have my 33inch toshiba in the center of my room.[with a screen fixed just above]corners could work ..but speaker placement would need proper adjustment.
