TV help Please !
Discussion in 'LCD & LED LCD TVs Forum' started by steveybrown, Jan 5, 2012.
Tags:
  1. steveybrown
    steveybrown
    Jan 5, 2012
    3
    Hello :D new here normally use other forums :(
    well im going to be gettig a new tv for my room and putting it on the wall above my desk and hooking it up to my computer but im stuck between what one i should get theres so many haha
    anyways these are three options which i have come to, feel free to give me more but these r best imo.
    Samsung UE32D6100 32-inch Widescreen Full HD 1080p 3D: Amazon.co.uk: Electronics
    (reading alot that 3D is not full HD so duno if worth spending the extra)
    Samsung UE32D5520 32-inch Widescreen Full HD 1080p: Amazon.co.uk: Electronics
    LG 32LV550T 32-inch Widescreen Full HD 1080p 100Hz LED: Amazon.co.uk: Electronics
    i will not be gaming on this so dont take that into consideration. however i will be hooking up my computer.
    so what do you think, which one is best ?
    steve
    price range 400 -450
  2. russ331
    russ331
    Dec 30, 2002
    634
    28
    +88
    Certain types of Panels are better suited for use as a monitor, i.e. text legibility, etc.
    I think (not 100% sure) that S-IPS Panels are best suited. S-IPS Panels are made by LG.
  3. steveybrown
    steveybrown
    Jan 5, 2012
    3
  4. GokuSS4
    GokuSS4
    Dec 31, 2011
    2,731
    87
    London
    +167
    Why would you even consider a tele like the ones you have mentioned if only for your PC and not gaming??? sorry just really confused.
  5. steveybrown
    steveybrown
    Jan 5, 2012
    3
    becasue i will be using it for TV also but i will also be using it to connect my pc up to it. i like the big screens as im a programmer and designer and prefer big real estate.
  6. GokuSS4
    GokuSS4
    Dec 31, 2011
    2,731
    87
    London
    +167
    I know quite a few programmers and designers and they use PC screens or Apple screens :confused:
  7. iaint
    iaint
    Jul 4, 2011
    640
    28
    +89
    Hi.
    Really would be better to get a proper monitor. For developing, you'd normally want a lot of useful real estate to read text from. In that respect, all those TVs are no better than my 15" laptop panel (1920x1200)!
    Consider the HP ZR30w for example; only 30", but a fairly impressive 2560x1600. Plus is has a proper adjustable desk stand (swivel, tilt and height). Plug a USB DVB-T tuner into your PC if you wish to watch television on it.
    Remember, a TV will be designed for you to sit between 2 and 3 times the vertical height away from it. Are you going to be sitting ~1.3m away from it?
    Regards, Iain.
