norfbech
Established Member
Hi folks.
I normally do a fair whack of research when I'm buying new kit (which isn't often) and this forum has been hugely helpful for past purchases.
However, I've a bit of a rushed scenario here as I need to help purchase a TV for my mother in law this weekend. She's currently not well in hospital, but it's possible she'll be out in a couple of weeks. Her family are currently fixing her living room extension into more of a recuperation room (will have a bed in there for a while). We live a couple of hundred miles away (my other half has been travelling to the hospital each weekend) so it's tough to visit. This weekend I'll drive down with the family and I've been tasked with sorting her a new TV (and fixing it to the wall...they're literally stripping the room of the furniture that does not need to be there...one of which was this old, wooden desk she sat her old, tiny LCD tv on).
Given the size of the room (and her viewing distance) I've suggested something around 40" (I think they would baulk at anything larger, although I think it would be fine considering I'm placing it on the wall).
Given I don't want to push their budget up (and I really don't think they'd appreciate it) I was not looking at the 4K screens. She definitely requires some kind of freeview and a facility to record TV.
I can't confirm but I think her connections are aerial point only: no connections from the Satellite dish though they have SKY TV in the other room (her Dad's domain!!).
So either built in freeview HD, or add a set top box into the budget. A real quick look suggests the BT Youview HD box might be an option? Currently around £130 (checked the area and it seems good to go). Might this be a better option than a built in freeview (from experience, my freeview on my Panasonic Plasma was nowhere near the quality of my Virgin box - SD or HD)?
I've not discussed the full budget but I'm assuming around £200-£300 for the TV and (if it's worth it) the Youview box on top.
She tends to buy her electrical stuff from a local shop in her village, but I said I'd shop around (did mention John Lewis, but looks like all their TV's are 4K, or at least the higher spec models).
Preferably looking at somewhere I can pick up in store at the weekend and set up the same day (I'll affix the bracket - possibly the Infusion - the same day too) - a trip to Currys perhaps.
Actually, I had a real quick look at Currys earlier: the JVC LT-40C860 popped up - 4k (which I wasn't contemplating) but at £350, worth a bit more research (also has HD freeview built in).
I guess this gives her the option of picking up a UHD set top box further down the line. However, I'm guessing the built in freeview won't have recording capabilities built in...so she'll require a seperate set top box already - the Youview UHD boxes are much pricier.
Should also add that they used BT - might be an option to add a subscription to include a Youviex box with this? (looks like the UHD box subscription is on offer and only £2 more per month than the HD package?).
Apologies if this is a bit long winded - essentially after a solid LED TV (around 40") with the best TV package offers (whether HD or UHD but with required storage). Quality of screen is perhaps (given the budget) a bit lower down than if the screen were for me.
I've used Virgin (and previous incarnations) for the past 20 years so no little about freeview boxes etc.
Hope someone can help!
Cheers.
norfbech
Cheers.
norfbech
