Tv for kitchen with build in tuner - suggestions?
Discussion in 'Televisions' started by empress, Jun 23, 2005.
  1. empress
    empress
    Im looking for a tv for the kitchen (so not looking for anything too big) and I would like to get one with a built in frreview tuner. Does anyone have any suggestions?
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    There are one or two 17" LCD IDTVs but I recommend first checking that you can get a good enough signal for digital in your kitchen Freeview transmissions are not normally strong enough for reception with indoor antennas. I did such a test and found that the only room in the house I could get Freeview in was the front bedroom, and then only with the aerial placed by the window.
  3. empress
    empress
    I have an aerial socket in the kitchen so will be using the outside diginal aerial so there is no problems with the signal.
