TV Fitting through Door.
Discussion in 'General TV Discussions Forum' started by ns1col, Aug 30, 2004.
  1. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I've a new 36" television coming tomorrow and I'm concerned that it won't fit through the front door. :rolleyes: Has anyone else who has had a 36" television delivered had this problem?
    Or, am I worrying about nothing?
    Colin.
  2. Pug72
    Pug72
    May 10, 2003
    2,153
    Hereford
    +341
    I had one delivered last year (it went back, long story).
    It would no way fit through the front.
    I had to take off the patio door around the back to get it in.
    Perhaps you can unpack it outside as a lot of the bulk is the packaging.
  3. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    It's either going through the front door or it's going back.(no patio door's). Hopefully with the box and all the packaging removed it'll come through. :rolleyes:
  4. oliver24
    oliver24
    Make sure you got a strong mate to help you, 36" will be very heavy if you have to unpack it on your door step
  5. headstate
    headstate
    i just bought a sony 32fq86 , in the box would not fit through the door!!!!! had to unpack it on the doorstep, and carry it in !!!!!!
  6. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Does anyone know if the depth of a television goes up as the screen size increase's? What I mean is, does the depth stay the same, but the length increase's as the overall size of a tv get's bigger?
  7. 42PW33
    42PW33
  8. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Thank's for the link 42PW33, I tried to find this the other day without success. :thumbsup: Now to measure the front door. :rolleyes:
  9. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I reckon I've got 70cm to play with so hopefully I'm worrying about nothing. :D
    It's still going to have to be unpacked before coming through the door. :laugh:
  10. 42PW33
    42PW33
    Let us know if it fits in, and then a small review if possible!
  11. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    ETA is between 3.45pm and 7.45pm today. I'll let you know when I've set her up. :thumbsup:
  12. Laurel&Hardy
    Laurel&Hardy
    The box will be just shy of a metre by 650, so just measure your door aperture and see if it'll go.
    Gerenal rule of thumb is that the bigger a TV screen gets the deeper it gets, especially with CRT. Reason? Focal length of the electron beam and the area (sweep) it has to cover. Projections are slightly different, but still follows the same general rule. My 51" is 570 deep, and the 57", which I considered but didn't go for because it was too difficult to accommodate, was over 600.
    Oh and the weight - expect at least 70 kilos for a 36"!
    If the team delivering it are also installing it they'll be able to work it out, unless your doors are only 2 feet wide!
  13. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Well you should know, Laurel &Hardy!
    Remember delivering that piano?
    :laugh: :laugh: :laugh:
  14. 42PW33
    42PW33
    Must be wedged in the door!
  15. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Sorry, ive spent the whole afternoon setting up the stand and my sony home cinema in a box and am now at work doing a nightshift until 7.00am
    The delivery men walked in through the door with the box :rotfl: I had about an hour of playing about before I left to come here.
    First thought's are that it's huge against my 28" and take's up a whole corner of my room. Watching dvd's was ok but I was scrutinising the screen close up and not from the distance I'll be watching it from. I mucked about with the setting's and got a decent dvd picture but I'll need to work on the freeview picture as this looked pants.
  16. 42PW33
    42PW33
    Have you had a chance to play about with your TV yet? Are you warming to the RGB pictur from Freeview?
  17. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    I've now set up my Sony DAVS888 home cinema in a box to output progressive scan and the dvd picture is up another notch. With the freeview picture via rgb, I think I'm seeing the limitation's of the freeview signal. Even the BBC channel's which should have the highest bitrate are not excellent.
    Still undecided.
    I think that the dvd picture through component progressive scan is now how I wan't it but the freeview picture will need some more work when I've finished this stint of nighshift's.
