Lee Gerard
I have a Labgear tv amplifier box with built in filters fitted with UHF aerial input and 3 TVs output. Was working perfectly with perfect signal strength and quality.
After a couple of days, the signal on all 3 TVs went, so the box had obviously failed. The light on the amplifier box was showing green, however, all of the cables were still connected so it had obviously failed.
I returned the box and swapped it for an identical replacement, and after a couple of days exactly the same thing happened again.
Can anyone advise as to what's happening? Could it be some kind of power surge, or may be a fault with the connection at the aerial end?
FYI I cut the plug and wired the box directly into an electrical switch box the first time and plugged the unit straight into a wall socket the second time, so it can't be a fault with the electric socket used.
Any help greatly appreciated.
Lee
Lee
