tv/dvd/vcr/sat connections
Discussion in 'Blu-ray & DVD Players & Recorders' started by chris the dev, Jan 3, 2005.
  1. chris the dev
    chris the dev
    I want to correctly set up/connect the following equipment:
    DVD Recorder (with 2 scart and an S-video connection - no other item has S-video, but I use it for the camcorder),
    VCR (with 2 scart connections),
    SKYbox (with 2 scart connstions),
    TV (with 2 scarts, and currently using a scart extension lead (x3)
    also --> stereo unit via red/white phono leads
    No websites seem to include all of these items in their connection diagrams!
    Can anyone assist?
    Many thanks
    Chris D.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    makes and models would help but AV2 TV>VCR(>)SKY>DVDR>AV1 TV (>) optional
  3. chris the dev
    chris the dev
    Thanks for the quick reply. I get a bit lost with all this AV1 AV2 business, and needed to know the correct sequence of connections.
    Re makes etc I only have basic info:
    TV = Grundig (old thing)
    VCR= Bush (18 months old)
    DVD-R= Samsung DVD-R100E
    Skybox = Grundig
    Any use?
    Chris D
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    how many scarts on TV?
  5. TommyT
    TommyT
    Dec 28, 2004
    52
    Glasgow
    Here is how I linked up a similar setup;
    TV (Scart 1) -> Telewest Scart (Marked TV)
    Telewest (Marked VCR) -> Sony DVD Recorder
    Sony DVD recorder -> TV (Scart2)
    Then I have an outside aerial into the "IN" of the Telewest Box
    Then I have a co-axial connection from "OUT" of the Telewest Box into "IN" of Sony DVD recorder.
    Then I have a co-axial connection from "OUT" of the Sony DVD recorder to TV aerial "IN".
    Later on I added a co-axial(RF) from "OUT" on the VCR to "IN" on the Sony DVD Recorder using a splitter that is attached to the "IN" of the Sony DVD Recorder so that it is able to take the 2 co-axials that are trying to get in there. Sometimes I feel that this affects the picture so usually just attach when I want to record a VHS tape (Home vid may I add...dont know if others will work/record) onto disk.
    Just as another note I also have a splitter that is attached to the aerial (RF) connection at the TV with a cable that is attached to upstairs TV so that I can watch Telewest upstairs.
    A little confusing I know..and not the best for picture quality for the purists...but does work to a reasonable quality considering my TV is old and not the best quality. I will use it until I get a better TV (LCD/plasma) then will think up something different to viewing quality.
    I also have the DVD attahced to a surround amplifier (Sherwood) and the sound quality is good.
    Now I can get really confusing :
    I also prefer to have a stand alone DVD player and a stand alone DivX player.
    I have to attach those to the TV by hand and unplug the Sony DVD Recorder Scart that is connected to Scart 2 on the TV, when I want to watch those. This is ok for me, considering I hardly ever get DVD's from video shop. Both those machines are connected to the Sherwood amp for quality sound too.
    Hope this helps you a bit...
    Cheers,
    Tommy
  6. chris the dev
    chris the dev
    Here are the precise connections to all my equipment:
    TV = AV1 scart, AV2 scart
    SkyBox = TV scart, VCR scart; RF out, aerial in
    VCR = ONE scart only (sorry, got it wrong first time, doh!!); ant in, ant out
    DVD-R = AV2 Ext scart AV1 TV scart; RF out, RF in
    Also, when I switch on the TV it defaults to AV1 with a rubbish picture, and sound when VCR is playing reverberates/echos!?!
    Chris D.
  7. jem
    jem
    Sep 24, 2002
    527
    +7
    As hornydragon says;
    Sky TV out to DVDR AV2
    DVDR AV1 to TV AV1
    VCR to TV AV2
    RF to VCR to DVDR to TV
    Set Sky to RGB
    Set DVDR to RGB on AV1 and AV2
  8. chris the dev
    chris the dev
    Cheers 'Hornydragon',
    So I need 3 RF leads?
  9. jem
    jem
    Sep 24, 2002
    527
    +7
    Yes.
  10. chris the dev
    chris the dev
    Done it!
    Thank you. Had to change the settings back to PAL as it wouldn't work with RGB!
    Will that cause any problems - recording etc....?
    Later
    CD
  11. chris the dev
    chris the dev
    Sorry Tommy T,
    I'm new to all this AV stuff. Reply too complicated for me to understand! Splitters, Sherwood, Telewest, Co-axial, LCD?!!!
    Thanks for taking the trouble to reply though. Problem now sorted!!
    Regards
    Chris D.
  12. jem
    jem
    Sep 24, 2002
    527
    +7
    What do you mean wouldn't work with RGB - what happens? Your recording quality will be far inferior without RGB.
  13. chris the dev
    chris the dev
    I got a blank screen. When I changed it back to PAl I got a picture!
    Wot do you reckon?
  14. jem
    jem
    Sep 24, 2002
    527
    +7
    Blank screen with only sound? It means it's not getting RGB into it. What scart socket are you using from your Sky digibox - VCR or TV?
  15. chris the dev
    chris the dev
    I was advised to connect SKY digibox to DVD-R via scart (AV2 connection on DVD-R).
    Then DVD-R AV1 to TV AV1
    then VCR to TV AV2
    RF to VCr, to DVD-R, to TV
  16. jem
    jem
    Sep 24, 2002
    527
    +7
    You've been advised correctly but you haven't answered my question.
    Which scart socket on your Sky digibox is connected to the DVDR - is it the one marked TV out or the one marked VCR out.
  17. BALLISTIX
    BALLISTIX
    Oct 7, 2004
    117
    16
    Maybe using a none RGB scart, hence no picture when set to RGB?
    Or as Jem suggests, yer plugged into the wrong orifice on the sky box :laugh:
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    does samsung DVD-R have RGB input? does it need to be set ot RGB in set up menu (should set for RGB in and out) wont allow for recording of VHS to DVD-R tho
  19. jem
    jem
    Sep 24, 2002
    527
    +7
    According to the manual on Samsung site it does have RGB input.
  20. jem
    jem
    Sep 24, 2002
    527
    +7
    Could be a few things;
    Non-RGB scart
    Using VCR out instead of TV out
    Sky not set to RGB
    Using the "TV" button on the Sky remote
  21. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    my NTL tuner has coax in/out but i cant figure out why - so i skipped it and went
    Aerial > VCR > HDD > TV
    Anyone know why digibox has aerial in/out ?
  22. chris the dev
    chris the dev
    Don't know. As per previous posting - (AV2 connection on DVD-R). ie Sky to AV2 on DVD-R
  23. chris the dev
    chris the dev
    I have already recorded form VHS to DVD - no problem!
  24. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    i tried chaining everything via scart but it wouldn't work unless the VCR was left on - consequently to the VCR out of the scart chain and went:
    Scart:
    Sky > TV
    Sky > DVDR > TV
    Coax:
    Aerial > VCR > DVDR > TV
    Tuned a channel for VCR on both TV and DVDR
    so you can record from VCR to DVD via coax
    record SKY to DVD
    watch Sky direct (whilst recording something else)
  25. JethroUK
    JethroUK
    Dec 5, 2004
    1,141
    but then you cant watch SKY when you're recording from internal tuner on DVDR
  26. jem
    jem
    Sep 24, 2002
    527
    +7
    Your Sky digibox has two scart sockets. If you want to record in RGB you need to be using the one marked "TV OUT" I was trying to explain that the reason you can only get a picture when set to PAL is that you may be using the wrong scart on your digibox.
  27. jem
    jem
    Sep 24, 2002
    527
    +7
    True but he wanted his VCR in the setup.
  28. chris the dev
    chris the dev
    wot do you mean? A gold scart lead as opposed to a 'silver' one?
  29. jem
    jem
    Sep 24, 2002
    527
    +7
    In case you want to have terrestial programmes or you may want to use the RF feed for a second TV.
  30. jem
    jem
    Sep 24, 2002
    527
    +7
    Where did I mention colour of scart?
