TV & DVD players calibration
Discussion in 'Blu-ray & DVD Players & Recorders' started by Benfica, Jan 10, 2005.
  1. Benfica
    Benfica
    Well, I really don't know what to do.
    I have a CRT TV 16:9 from Sony, and 3 DVD players:
    - Onkyo DV535
    - Pioneer 575
    - Pioneer DVR-5100 (this is a DVD recorder).
    My question is: I do I calibrate my TV and DVD players in order to get the same (or closest to that) image in my TV when playing the same DVD from each of the 3 DVD players mentioned ?
    I can't say that there is a HUGE diference in my actual setup, but there is some.
    My 3 DVD players are connect to my TV through a 3 way RGB scart switch box (my TV has only one RGB scart input). They are all in the default configurations regarding picture adjustments.
    I have calibrated my TV using some advices / tips mentioned in some specialized magazines, wich at that time proved to improve a lot on the picture quality.
    Can you guys help me out ? From where do I start ?
    Note: I've ordered on-line the DVE (Digital Video Essentials), but not received it yet.
    Thanks in advance.
  2. Benfica
    Benfica
    Ok ... no answers until now .... can I presume this is a stupid question ?
    If not, please someone care to help me ?
    My DVE is on the way ...
    Best regards
  3. jrosado
    jrosado
    Feb 14, 2004
    172
    Portugal
    Hi:
    If there is only a scart with RGB, and if all 3 players must be connected to that scart, there is no way you can calibrate the tv for the 3 players. You have to choose which one you want to use more and calibrate for that one.
    Regards,
    J. Rosado
  4. Razor
    Razor
    Dec 15, 2004
    37,550
    2
    +12,508
    Scart switch box or an amp should sort you out.
