P
pallismn
I am in the process of building a new PC for work, and specced an ATI all in wonder 8500 DV, largely because it would give me firewire and vidio editing. Whilst waiting for the rest of the components to arrive I have installed it into my old PC, and tried attaching it to the TV.
I would quite like to install the old PC as a TiVo/DVD-R alternative, as I think I could do it with the old PC plus £150 for a ATI AIW and £200 for a DVD writer. If it works, I can also get rid of the tuner, VCR and CD player from the room and may then upgrade to a neater case (like a coolermaster 600 or something).
Well that is the background. My question relates to the use of a TV as a display. I have it working but it is not perfect
1. The desktop is bigger than the screen, so I have to scroll around to see everything, although I can size the vieo display to fit the display area.
2. Whilst the TV and video picture quality is OK, the rest of the display is not too good. There is no way you would want to use it to surf the internet (to see what is on telly for example).
I have a B&O MV1000 telly
Is this normal or have I not got it set up correctly? Is using a PC with a TV (as opposed to Plasma or projector) just impractical?
Mike
Mike
