TV Dimensions 55” vs 65” when wall mounted
priesty_lfc
Hey guys.
Finally getting my set up finished but just had a thought and now not 100% I can have what I had planned.
Currently have a 55” AF9 wall mounted with a Sonus Arc mounted below, when I had it mounted I made sure the wall mount could take a bigger tv but now looking at the dimensions between a 55” and a 65” there is roughy 10cms height difference.
does anybody have any idea how that translate in respect of mount fixings? Is it roughly 5cm top and bottom? I have a horrible feeling a 65” will overlap with the sonus arc.
I’m not going to remount anything so I’m unsure if I can upgrade to 65 or if I’m stuck with a 55”
priesty_lfc
I actually assumed they were all in the same place, so that might not be the case?
I didn’t wall mount my tv I paid a company to do it, looking at the bracket they used it seems that the fixing to the tv is slidable in which case I can just attach it lower to hopefully give me more space.
martin 39
Mate of mine has just changed from a 55 panasonic oled to a 65 panasonic oled and it went straight on the wall bracket same markings on brackets perfectly fine. We were both amazed how quick it took to swap over
