tv connections?
Discussion in 'General TV Discussions Forum' started by nickyourtv, Feb 24, 2002.
  1. nickyourtv
    nickyourtv
    Feb 24, 2002
    5
    Im getting my home cinema system soon, (my first step into the DVD world) and could do with a few questions answering.
    Ive decided to go for the Panny tx32pb50 (£1149),
    I dont have space for a seperate amp and 36in is out coz it will block half of the window.
    for my DVD player ive opted for the pioneer dv545 (£229), only for its sound/picture quality.
    my real problem is the connections?
    Im probably going to get a QED av21 (0.5m) but as the 545 dosent have a built in dolby digital decoder will i also need a digital cable?
    if so would a rgb only scart be better?
    My knowledge of connections is sketchy at best so help in this area would be much appreciated.
  2. Guest
    Yes, from the DVD to your TV's digital decoder input. I'm guessing it will have an optical one.
    Graham
  3. bob007
    bob007
    Am i seeing double, i could have sworn i posted a reply to this same question on the DVD forum.............:eek:
