TV Connection
Discussion in 'Projectors, Screens & Video Processors' started by andy21, Jan 23, 2001.
  1. andy21
    andy21
    can anyone give me some advice on connecting my SKy digibox to my ctx projector. It has s-video and composite connections, but how do i connect digibox to it as it has only scart connections
    Any help appreciated
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,210
    +3,048
    Andy,
    Get a Scart to 1 phono lead ( or BNC if that's the connector for composite on your projector)Ask the shop to wire up the scart end for "video out" it's pin19 SIGNAL and pin17 EARTH. Use good quality screened 75ohm interconnet for this. We use Ecosse Reference's Digital interconnect cable!
    Alternatively, if you want better quality, get a decent fully wired scart, tell your skybox to output RGB, then buy an RGB to S-Vid downconvertor. I can direct you to a supplier or supply one for you. Then buy a long, decent, s-video lead.
    Hope this helps.
    Gordon
    StereoStereo
    Intelligent Solutions for Intelligent Homes !
