We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
tv card
Discussion in 'Microsoft Windows' started by bigdavie0, Oct 21, 2005.
  1. bigdavie0
    bigdavie0
    :lease: what tv card will i need .
    i have built a htpc and now looking for a tv card but what one do i buy,ihave got sky digi,does the card i am looking for need to be analoge or digi,also will you recommend a good card :clap:
  2. deksawyer
    deksawyer
    May 26, 2005
    1,641
    Fife, Scotland
    +132
    Hauppauge PVR150.
    Both the MCE/non MCE branded versions will work as long as you use the MCE driver.
    D.
  3. bigdavie0
    bigdavie0
    :lease: i have purchased pvr 150 mce and just wondering how to connect to sky and tv :thumbsup:
  4. geroffme
    geroffme
    You need to get a signal from your Sky box to the PVR card. Use a normal (rf) aerial cable to run between the two. You then need to get a signal from your graphics card to your TV/monitor. This will depend on what inputs your TV has and what outputs your graphics card has - you might need some sort of adpater. Good luck.
  5. Rambles
    Rambles
    Jul 14, 2004
    10,593
    167
    UK
    +2,242
    As above, but s-video may be preferable to connect your sky box to the pc, better than rf.
  6. Spacecat
    Spacecat
    Apr 1, 2001
    3,446
    London
    +1,124
    ATI 550 pro Superb
