TV capture/in cards for HTPC use?
Discussion in 'Desktop & Laptop Computers Forum' started by Kramer, Mar 15, 2002.
  1. Kramer
    Kramer
    What's recommended for running an S-video signal through my PC, using D-Scaler, to feed a Panasonic PT-AE100.
    My Sky digibox has S-video out & I'm using a Radeon 7500 with the DVI feeding a flat panel & VGA going to the projector. I'm only running the VGA out during DVD play.
    I don't want to spend crazy money. A PCI Win TV card perhaps(with S-video in)?
    Any recommendations appreciated;)
  2. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,217
    UK.
    +2,758
    I used a Pinnacle PCTV Rave card which cost me just £30, and it does a reasonable job with DScaler. It has some visible noise in it, but the picture is better than standard s-video is on my pj.
    Cards do vary, but for the price, you can't go wrong really.
    If you want to spend more money and get a better picture, I believe the IDS Falcon card is meant to be very good - there's a thread on here somewhere about it, so it wouldn't hurt to have a read...
    Gary.
  3. jrwood
    jrwood
