malrobb
HI All,
I have just ordered a new TV (Samsung UE55KU6400) and am going to use it with a Playbar. I bought a fixed bracket for the Sonos Playbar but am in in a bit of a dilemma around the TV bracket. Its being mounted on a brick wall and I have installed sockets half way up the wall and am therefore unsure if i can get a fixed bracket as the TV cord once plugged in will cause the plug to not allow the TV to sit flush. If I go for a cantilever bracket then I am concerned that the cables (optical connecting cable to the TV) will get pulled out etc.
I have seen a one piece bracket that mounts the TV and PLaybar together so that bot the TV and PLaybar moves but not a fan of this and it costs about £400
Appreciate any advice anyone can provide as to how to solve this problem.
Mal
Mal
